Engine "shakes" every once in a while
Old Aug 20, 2013 | 11:51 AM
gipfelhonkH2's Avatar
Default Engine "shakes" every once in a while
Hi everyone,
my 2005 H2's engine acts up occasionally and the RPM collapses for a split second so that the whole car shakes a little as if you rode over a small bump. It happens around 1300 and 2000 RPM.
When I bought the car I interpreted it as road bumps so it is not that noticeable. I just happened to look closer as the check engine light lit up on my way home. The error memory says P0332 and P0327 which means that both knock sensors have low voltage. However, the mechanic said it was almost impossible that both knock sensors break.
I would really appreciate your help!
Old Aug 20, 2013 | 07:57 PM
burnt orange hummer's Avatar
i had this same problem on my h2 my mechanic finally figured it out it was the intake manifold there made of plastic so they warp might want to have a smoke test done on it to see if you have air leaks. hope this helps.
Old Aug 22, 2013 | 09:58 AM
Thank you, I'll definitely try that!
I have an appointment with an autoshop next week. I'll let you guys know whether and how we were able to fix it.
Big Sam
Mar 13, 2015 10:04 PM
amyandmark3
30
Dec 8, 2012 04:28 AM
Perantes
Nov 12, 2011 03:27 PM
RENNtech
Oct 1, 2010 06:55 AM
chsnprodigy
Apr 7, 2007 02:35 PM
