Electrical bug
Old Nov 22, 2019 | 08:35 AM
flynripped's Avatar
Default Electrical bug
So I got another electrical problemin my 04 H2 350,000kmI jumped in my truck and when I fired it up the battery seemed weak and all my gauges don’t work except speedo and tack my stereo windows don’t work and the display says unknown driver. When I got home from work I Disconnected the battery waited 10 minutes hooked it back up and everything seem to be back to normal when I got up in the morning fired up the truck same issue started do you guys have any ideas
Old Nov 22, 2019 | 08:57 AM
We have no ideas because you failed to include what you are talking about.
WHAT VEHICLE ARE YOU ASKING QUESTIONS ABOUT???? Year, Model, Miles and a description of any recent work done before the problem you describe would all be important information.
Old Nov 22, 2019 | 12:55 PM
get the battery tested.
Old Nov 22, 2019 | 12:58 PM
Get the new Raid Electrical Bug Killer.
Thanks for updating the info. X2 on what bronteck said.
Old Nov 22, 2019 | 01:51 PM
flynripped's Avatar
04 H2 350,000km I put a new alt and battery in 8 months ago the trucks been running fine last week my rear passenger door said it was ajar and it was fully closed so bat went dead and now this issue has happened but problem free for a week
Old Nov 22, 2019 | 02:00 PM
#1- Test battery resting voltage
#2- Test parasitic draw
Old Nov 22, 2019 | 02:03 PM
Door left open should not kill the battery. There are two circuits. Retained accessory power keeps certain things powered after the key is shut off until a door is opened like the radio. The inadvertent power supply voltage circuit provides battery positive voltage to all of the interior reading lamps, instrument panel (I/P) compartment lamp, and both visor vanity mirror lamps. In the event that any of these lamps were to remain illuminated for a period of more than 10 minutes with the ignition switch in the OFF position, the BCM will deactivate the inadvertent power supply voltage circuit to prevent a total battery discharge condition.
Does not matter if your battery or alternator are 1 day old or 4 years old. Either can go bad and are something to check. With the issues you mentioned in the first post though I'd suspect water intrusion may have gotten into the BCM or you might have some ground issues somewhere.
Old Dec 7, 2019 | 04:34 PM
flynripped's Avatar
So after the battery died my issues started so they warranted the bat and seems to be fine so far
Old Dec 8, 2019 | 05:43 AM
Booch's Avatar
I had the same issue and after many hours of troubleshooting, I found the ground on the air compressor module was rotted away. I Removed the compressor tray since the vehicle has coils springs now and I then sealed off the connections.
Prochrgd1
Feb 7, 2018 09:10 PM
atari800
Jan 31, 2016 07:30 PM
cristalelectric@hotmail.com
Oct 19, 2012 08:41 PM
Champ53
Jul 19, 2011 02:26 PM
jobenshain
May 12, 2007 06:29 PM
