E85
You can't just decide to run E85. In order for a modern engine to do this, the computer senses when its on E85 and makes adjustment for timing and fuel flow. E85 needs about 30% more fuel than regular gas. It burns cleaner but you need more of it.
The ethenol will also eat up every bit of rubber in the fuel system.
Tim
Tim
Stock injectors and fuel pump would need to be upgraded likely along with a tune. It really isn’t worth messing with.
09s are flex fuel and can do it but who knows how well it will work.
Someone will correct me if I’m wrong but e85 if it’s setup properly would run just as well as premium gas just with less mileage as it’s less dense and burns cooler.
