E85
Old Jan 14, 2023 | 08:38 AM
Zaniac's Avatar
Default E85
Is anyone using E85 fuel in their H2? How is working out?
Old Jan 17, 2023 | 08:57 AM
HellHoof's Avatar
My 2008 runs poor on 87 octane. I can't imagine it doing anything with E85.
Old Jan 26, 2023 | 09:21 AM
Daniel Z's Avatar
No way. 87 on ours also makes it run like crap. 89/93 is what I use. And thanks Joe for the ridiculous high gas prices. Get ready it’s about to get more expensive again.
Old Jan 27, 2023 | 09:32 AM
Zaniac's Avatar
Default chip or any other performance
Thanks!
do you use a chip or any other performance products?
Z
Old Jan 27, 2023 | 09:33 AM
HellHoof's Avatar
Bone stock other than 37" tires. Pretty peppy, although slightly slower with the larger tires compared to stock.
Old Jan 27, 2023 | 03:17 PM
tharber's Avatar
You can't just decide to run E85. In order for a modern engine to do this, the computer senses when its on E85 and makes adjustment for timing and fuel flow. E85 needs about 30% more fuel than regular gas. It burns cleaner but you need more of it.
The ethenol will also eat up every bit of rubber in the fuel system.
Tim
Old Jan 31, 2023 | 07:35 PM
Gavin Costigan's Avatar
Stock injectors and fuel pump would need to be upgraded likely along with a tune. It really isn’t worth messing with.
09s are flex fuel and can do it but who knows how well it will work.
Someone will correct me if I’m wrong but e85 if it’s setup properly would run just as well as premium gas just with less mileage as it’s less dense and burns cooler.
rsarol
May 12, 2022 09:47 AM
yardcrew
Aug 12, 2014 08:06 PM
palmxjjsi
Jul 26, 2011 01:12 PM
fuellegacy
Oct 24, 2008 07:22 AM
hotrod
Oct 20, 2008 02:37 AM
