DRL Issue: daytime running lights stopped working
Old Apr 17, 2023 | 05:46 PM
H2Finally's Avatar
Default DRL Issue: daytime running lights stopped working
DRL Hummer H2 Daylight Running Lights NOT working. Fuse inhood good, relay good, photocell good (headlight turns on at night).
Checked with different bulb, still NO DRL when gear is in Drive.
This is a recent as of a week or so ago issue. What else can I check to troubleshoot?
Old Apr 17, 2023 | 06:19 PM
Old Apr 17, 2023 | 08:56 PM
i think they ground at the bumper bar
Old Apr 18, 2023 | 01:04 PM
H2Finally's Avatar
Default YES! nooo 😔
You’re right thank you! Mike Matthews at another forum also recommended the same. Cleaning up the DRL ground (on my H2 04 it’s located by the front driver body mount bushing), works to restore my DRL! (After couple of restarts).
update: alas, the joy was temporary. DRL stopped working again. Right now I’m leaning towards BCM going bad
Old Apr 29, 2023 | 05:54 AM
Daniel Z's Avatar
Was is the ground?
Old May 1, 2023 | 07:51 PM
H2Finally's Avatar
Originally Posted by Daniel Z
Was is the ground?
Unfortunately still a mystery. Ground is clean & screw very tight, but the DRL still randomly turns on / off at ignition start (mostly off ☹️)
Old May 2, 2023 | 09:58 AM
have you swapped the drl relay located in the main under hood fuse box? i know you said it was good but maybe it is intermittent?
https://fuse-box.info/hummer/hummer-...ses-and-relays
jlopez
Aug 30, 2013 06:28 PM
kav315
Aug 28, 2012 08:48 PM
jssowell
Sep 24, 2011 10:49 PM
Harley H3
21
Mar 13, 2010 12:09 PM
blacksc
Apr 19, 2009 12:54 PM
