OIl pressure sending unit Pigtail
Old May 3, 2023 | 06:58 AM
Booch's Avatar
Default OIl pressure sending unit Pigtail
So yesterday Eve got in the vehicle to go to dinner and the oil pressure jumped to 80 PSI, I was perplexed as I swapped the sender out about a month ago with a new ac delco one, then I noticed it jumped when just the key was on too, so I figured a stepper motor, I have a good cluster and tested it "the same thing", so I'm curious has anyone had these symptoms for 80 PSI engine on or off and did you figure the issue out. I'm leaning toward it being the pigtail but any suggestions would be appreciated.
I figured it out "BAD SENSOR" I swapped in my old one and it works, wow ACDELCO sensor lasted a whole month.
zachakamp
Aug 23, 2021 11:40 AM
Josh Scott
Oct 1, 2019 11:59 AM
Tamerlaine
Jan 28, 2016 08:57 PM
Ghost Rider
20
Jan 20, 2016 10:22 AM
RAHF
Oct 29, 2014 07:27 AM
