Door Panel Trim ID?
Old Jan 20, 2020 | 09:40 PM
dpaul6590's Avatar
Default Door Panel Trim ID?
Is there anyone that may be able to identify these door panel guards/trim?
The only things similar I can seem to find are all stainless steel and do not have the bolts. The bolts almost look like they were added after, but I still cannot find any similar trim by itself.
Thanks in advance.
Old Jan 20, 2020 | 10:09 PM
Flashback to the 70's.. cover up rusted doors with tin.
Old Jan 21, 2020 | 11:47 AM
looks like they just drilled in self tapping screws. i doubt it came like that.
Old Jan 21, 2020 | 03:26 PM
Chrmer3's Avatar
I concur- looks like 5/16" self tap screws -lol
Old Jan 21, 2020 | 05:47 PM
Agreed. At least they look like stainless steel. Panels looks like some sort of plastic about a quarter inch thick and routed to shape. If those are indeed drillers screwed into the door the doors are pretty much ruined. Now if they are decorative and do not really go through and the panels are simply stuck on with VHB tape then not so bad. That would be the way to go and woudl actually be very easy to recreate. Just get a plastic that is UV resistant and will not warp outdoors from a plastics supplier like Polymershapes, make a pattern, route it. Take a bunch of stainless bolts, rivets, whatever, drill/glue them to the plastic, get some VHB tape and stick it to the doors.
hummer_on_fumes
Feb 2, 2021 01:57 PM
mgurgone
Nov 4, 2011 07:35 AM
E T H
Apr 9, 2011 10:19 PM
jeffwhiteis
Jul 19, 2010 04:49 PM
BIGT2148
Oct 20, 2009 12:57 PM
