De-Chroming w/ Rust-Oleum Spray Paint
Old Dec 23, 2020 | 12:56 PM
Chad James's Avatar
Default De-Chroming w/ Rust-Oleum Spray Paint
I’m sure this has been done in the past, but I thought I’d share my experience.
I am painting over the chrome bits on my Hummer with Rust-Oleum in Matte Hammered. I figured if I mess it up, I can always wrap them in the future.
H3 with chrome trim. “before”
Removed the handles first. Masked the back side of the handles and plastic parts.
Used a medium box and cut holes in it to hold the parts in, and keep them upright for painting.
Example (sample) of a center cap spray painted with Rust-oleum in matte hammered. Used a dremel to remove the paint over the Hummer label and accent.
Old Dec 23, 2020 | 04:53 PM
wpage's Avatar
Well done bro...
Old Dec 23, 2020 | 09:23 PM
Chad James's Avatar
Thanks, hopefully it looks nice after install and lasts.
Old Dec 24, 2020 | 04:47 PM
UcraDen's Avatar
Dude, I would apply some soft sandpaper, to make it more abrasive... let see how long it will last.
Old Dec 25, 2020 | 08:23 AM
HappyCamper's Avatar
looks great- plans to do the front grill?
Old Dec 26, 2020 | 01:27 PM
Chad James's Avatar
I definitely do plan on doing the grill as well as the mirrors. The nerf bars will eventually be removed all together.
Old Dec 26, 2020 | 01:31 PM
Chad James's Avatar
yeah, I ended up using a 120grit. And honestly, being handles, I don’t expect the paint to last very long; which is ok. Might end up wrapping them in the future if that’s the case.
Old Dec 26, 2020 | 01:32 PM
Chad James's Avatar
Old Dec 26, 2020 | 02:16 PM
UcraDen's Avatar
I normally don't like paintvthe plastic, let alnoe the parts you'll touch all the time, because the paint doesn't hold on properly.
I paint the chomed and cracked grill on my hummer, just because I couldn't find proper replacement, we will see how long it will work...
Normally to make proper job, you should remove the chrome completely. To do such from my mags, I spent 800$ for 5......
Old Dec 26, 2020 | 02:34 PM
Give plenty time to cure, dry heat best to cure, then a coat or 2 with clear acrylic sealer.
