The brakes seem to engage when I turn the wheel past a couple turns at low speeds
Old Nov 27, 2021 | 11:52 AM
Broncoguy27's Avatar
Default The brakes seem to engage when I turn the wheel past a couple turns at low speeds
Sorry about providing so much fodder here. When I turn the wheel past a couple turns, at parking lot speeds, the brakes seem to engage whether I'm going forwards or backwards. As soon as I straighten the wheel, the problem seems to take care of itself. Any input on this, this is a new one but this is my first hydro boost vehicle too
Old Nov 27, 2021 | 12:51 PM
Gavin Costigan's Avatar
I’m not an expert on hydroboost so someone correct me if I’m wrong, but I don’t think steering input would cause an increase in pressure to the brakes.
Verify that the vehicle is not in 4hi Lock or 4lo lock. Try cycling between 4hi lock and 4hi. Also driving around reverse and forwards. The actuator can often become stuck in lock despite what the indicator says.
4hi lock and 4lo lock will cause the driveline to bind up when turning on a grippy surface because the wheels aren’t able to move at different speeds. Try giving it a little gas and see if the vehicle hops and moves.
Old Nov 27, 2021 | 12:59 PM
brakes being applied when turning is one of the signs of a bad hydro boost
https://www.autoinc.org/diagnose-hydro-boost-brakes-3/
Old Nov 27, 2021 | 01:03 PM
See. I said I knew nothing about hydro boost😂
Old Nov 27, 2021 | 02:39 PM
Default Me big dummy....
Some idiot left it in 4 high after driving in the snow....don't ask who.
Old Nov 27, 2021 | 03:11 PM
That's all it was? Lol. At least you don't have to buy a new hydroboost. Luckily the driveline in the h2 is beefy enough that you likely didn't tear anything up.
Old Nov 27, 2021 | 03:48 PM
That is also a sign of a failing hydroboost as mentioned though. Mine did exactly that. You could physically even watch the brake pedal go down some when turning the steering wheel.
Glad it was much simpler on yours. lol
Old Nov 27, 2021 | 03:51 PM
Default I felt kinda dumb...
I totally forgot I drove it through significant snow the night before.
Old Nov 27, 2021 | 05:15 PM
X2, TC has no effect on the hydroboost! Hydro-Boost Power Assist Systems: Operation Diagnosis and Repair
ozark1
Aug 13, 2019 09:51 AM
Indyone
Apr 29, 2013 06:07 PM
zderekv
41
Jan 25, 2013 10:31 PM
zefrum
May 3, 2011 03:57 PM
gotafish
Mar 23, 2010 10:37 AM
