Brake lines, electronic brake control module, and brake pressure modulator valve
Old Jan 7, 2019 | 04:48 PM
Mark Maturen's Avatar
Default Brake lines, electronic brake control module, and brake pressure modulator valve
the local “stealer” (er, dealer) in atlanta says I need all new brake lines, the EBCM (electronic brake control module), BPMV (brake pressure modulator valve), a steering position sensor, and intake manifold gaskets. Whew. They are asking big bucks to fix. I don’t trust them due to a variety of reasons. Thoughts on where to find less expensive parts...and who can fix?
Old Jan 7, 2019 | 08:17 PM
hummer_on_fumes's Avatar
As far as the EBCM goes, you can get it refurbished through eBay rather than buying a new one. Mine was throwing a slew of codes randomly. I got it repaired for $100 and it's worked like new ever since.
If the brake lines are leaking or rusted through you'll definitely want to get them replaced. You don't want to try stopping in a massive Hummer and have your brake pedal turn to mush, it is a very scary situation
Old Jan 8, 2019 | 11:35 AM
FatJay's Avatar
I haven't looked at the brake lines on the h2 yet, but most cars they're pre-bent hard lines, and nothing short of a nightmare to install, and expensive. I wish they'd come up with a viable solution for soft lines but i haven't seen it yet. They're exposed to the elements, especially if you far enough north to get snow and salt. They rust out and if they burst, it's not pretty. I always get the underside of my cars/trucks washed in the spring to clear all that salt out, otherwise it just eats away at stuff.
ENASNI
Oct 13, 2019 03:16 PM
oceanbrave
Jul 30, 2018 04:37 PM
ayojel
May 15, 2012 10:34 AM
CMNSTER
Feb 4, 2009 06:04 PM
shortbus
Jan 17, 2006 11:37 AM
