Brake Line Spares
Old Jul 27, 2018 | 10:30 AM
oceanbrave's Avatar
Default Brake Line Spares
After a recent catastrophic brake line failure (broken pipe from ABS unit to front driver's wheel) I live on top of a steep hill but fortunately the H2 was on my driveway when it failed otherwise it could have been deadly.
So it looks like a good time to replace all the brake lines and attend to the system carefully.
In the UK brake lines and fittings are metric but I see I can easily buy complete sets of brake lines or even kits on ebay. I'm also looking for "Brake Bleeders" or "Calliper Bleed Screws" if I have the terminology right, over here we'd call them "bleed nipples"
Plain steel does not seem to be a good option, however I see Stainless Steel kits available. Again in the UK we'd most likely fit copper lines which are easy to bend, don't rust and comes on a roll.
So before I go out and buy stuff does anyone have any reccomendations, suppliers etc. Cheers!
Old Jul 27, 2018 | 02:06 PM
NoSpoon's Avatar
I replaced all of mine after one began to leak w/ NiCopp lines that I bent and flared myself. If I had it all to do over again I would buy the pre-bent stainless lines and install those. I also replaced the rubber hoses with braided stainless ones. I did a ton of research through the forums and I saved a note of what sizes and fittings if you choose to go the NiCopp route.
Good luck!
Old Jul 28, 2018 | 07:32 AM
calif phil's Avatar
Even though the brake lines are probably 3/16 th. I believe the fittings are metric. The factory plain steel is known to rust, I would opt for the stainless steel kit or the NiCopp that you can fabricate yourself.
Old Jul 30, 2018 | 04:37 PM
oceanbrave's Avatar
Thanks for the comments guys, I'll post my results in a few weeks!
ak47dennis
Aug 22, 2025 02:30 AM
ENASNI
Oct 13, 2019 03:16 PM
CARdiac
Mar 20, 2016 08:02 PM
shortbus
Jan 17, 2006 11:37 AM
