Body Mounts
Old Dec 26, 2024 | 08:38 PM
RobertDez's Avatar
That body mount pictured above is the original, 22 years old. I don't see much of an advantage on the expensive urethane....
Old Dec 26, 2024 | 11:19 PM
let us know how they work out. from what i remember i think 4 out of the 12 are different.
Old Dec 27, 2024 | 10:51 PM
finall's Avatar
Your rubber mounts look red. Never seen red OEM ones. Anyone else?
Old Dec 27, 2024 | 10:58 PM
finall's Avatar
look in the video at 2:40 minutes in there is a metal cap that looks like a mushroom that you have to transfer to the new body mounts. it gets inserted between the body and the top bushing. they rot out. in the video his are not in the best shape.
this one has a rubber bushing installed.
Mushroom caps can be reused if not rotted out. Important! there are also shims sold by GM. You need the shims IF your bushing-to-frame space varies between adjacent body mounts. You also need to replace the large fender washers, bolts, and bolt washers if replacement bolts do not have the OEM style mushroom heads. And they have to be Grade 8, NOT cheapo grade 5.
If you snap a bolt, you are in a world of pain. They get super thin from wear. So lube them up prior to your ratchet lovemaking.
Old Dec 27, 2024 | 11:40 PM
RobertDez's Avatar
I've got the maintenance records from the previous owner, nothing in there about motor mounts. I assume they're stock.... But have no clue. The whole underside is fairly clean, no rust.
Kavik001
May 4, 2023 11:46 PM
ejsmall
May 1, 2023 09:37 PM
Domh3
Nov 6, 2020 05:48 AM
KA H2
Sep 18, 2012 09:31 AM
joewcob3
Sep 14, 2008 09:00 PM
