Blower Motor
Old Aug 26, 2025 | 04:55 AM
oceanbrave's Avatar
Solving Hummer problems can be enjoyable, however often we never get to learn that all important feedback from the users, such is the nature of forums.
Old Aug 27, 2025 | 08:02 PM
Chrmer3's Avatar
I will also toss this out there in regards to both the blower motor & resistor- IF you have a failure on either or both in a short period- check under the front cowl (the trim piece between the windshield and hood) it will pull up - (has retainer clips on it like the center console drink holder), along with removing the windshield wiper arms (pull clip come right off) and a couple screws if memory serves me right? Underneath the cowl, right side, is a black plastic cover (air intake for cabin) with what is now a 20 year old seal- when that seal falls off/degrades water/rain WILL enter the duct system and potentially screw up the blower motor & resistor.....It pulls up to remove (forgot exactly how) Clean up the surface and you can use rtv silicon to establish & create a new seal for that cover. Not a bad idea to check this area, the gasket was shot on mine & suspect thats what took out the blower resistor... the motor bearings also locked up - I'm sure moisture got that also, however 20 years of use- it was due regardless. When you view this for the first time- you will not believe how "cheezy" this intake design is.... water literally runs down the windshield & straight into your duct if/when that seal fails..... Check it if you notice any moisture in duct system or doing preventative maintenance...
Fatterduke
Aug 15, 2023 11:37 AM
waltham41
Aug 8, 2022 01:02 PM
humm309
Jul 1, 2020 10:53 PM
Mark68
Sep 16, 2019 04:33 AM
EVILKING
Feb 12, 2015 05:49 AM
