Blend Door Actuator Replacement
#131
HVAC System Malfunction
I have a 2003 Hummer H2. I have similar problem with air being diverted to the defrosters and nothing coming out of the dash vents? Would replacement of the hvac panel mode door actuator solve this problem? And, is the actuator located on passenger or drivers side? Any help here is greatly appreciated!
Larry
#133
have an H2 2008
Hi all, the re-circulation actuator was stuck... prior to replacing it, i plugged the new actuator, the motor was in the middle (new actuator), when i turned the key position to on, the actuator motor turned 3 times (from the middle to left then right then left). I turned on the AC and pressed the re circulation button, the motor is not rotating and remains in the same position.
Please advise.
Please advise.
jmudler
04-07-2015 09:45 AM
CHP
03-05-2013 06:18 PM
ingydrummer
02-19-2012 09:38 AM
