best steering stabilizer shock for our truck?
Old Oct 28, 2019 | 01:17 PM
hnijhar's Avatar
Default best steering stabilizer shock for our truck?
got a 2003 hummer h2, and ill probably be getting some budget shocks as ill only be running this truck for another year or two. I will also change my steering stabilizer and was thinking of maybe using a good steering stabilizer like a bilstein or something? or should you always wear the same steering stabilizer as the brand of shocks?
which steering stabilizer is good for our truck?
thx
Old Oct 28, 2019 | 01:44 PM
LoJac963's Avatar
When I did all four shocks with Bilstein 5100s I did the 5100 steering stab also. It is very stiff and does not return to center on its own but I also do not put many miles on the old lady anymore. I am sure if it were a DD it would loosen up over time.
Old Oct 28, 2019 | 03:29 PM
from what I have seen I think the only one that works as it's supposed to is the OEM one. the rest tend to pull or push.
Old Oct 28, 2019 | 03:41 PM
I've seen posts indicating the same.... other put an aftermarket one on and have ended up taking the aftermarket one back off and getting and OEM one and putting that on instead.
Old Oct 28, 2019 | 05:32 PM
LoJac963's Avatar
I had similar concerns when I installed mine but it neither pushes or pulls. It is just stiff and doesn't return to center without a little help. It definitely won't be coming off since I trashed the stockers lol.
Old Oct 28, 2019 | 06:49 PM
yup thats the other issue i forgot.
JayRay199
Aug 11, 2017 11:35 PM
flyday58
Nov 11, 2016 10:59 AM
Treviso
21
Apr 15, 2016 09:30 PM
madmayo
Apr 15, 2016 11:29 AM
solarflare
Jul 11, 2011 10:01 PM
