Battery Not Charging message
Old Dec 8, 2022 | 10:15 PM
2005H2's Avatar
Default Battery Not Charging message
Hi everyone,
I have a "Battery Not Charging" alert, it's never happened before. Is the cause typically a bad alternator?
Thanks!
Old Dec 9, 2022 | 09:12 AM
That would be my guess. If you have a multimeter you can verify. Set it to DC and see what the voltage on the battery is with the engine off then check with the engine running. The voltage should be higher when the engine is running. Off should be about 12.8v or less. Then test again with the engine running and it should be above 13v. This is not comprehensive but it is the most basic verification that the alternator is at least doing something.
If that fails then a bit more in depth testing would be needed to be certain that it is indeed the alternator or if there is some other issue like a wiring fault.
Old Dec 9, 2022 | 10:33 AM
do you still have a serpentine belt? simple checks first.
Old Dec 9, 2022 | 06:48 PM
Check voltage at alternator.
Old Dec 16, 2022 | 10:50 PM
2005H2's Avatar
It was a bad alternator. Easy fix.
Venomous
Feb 20, 2021 06:11 AM
curleymon
Jan 19, 2019 10:49 AM
DeMopar
16
Mar 11, 2017 06:33 PM
Tech5
Mar 17, 2011 10:32 AM
mach1nm
Jan 3, 2011 05:48 PM
