Battery/charging issue?
Old Jan 1, 2011 | 06:15 AM
mach1nm's Avatar
Default Battery/charging issue?
So truck started out last night flashing battery not charging while at the gas station but after got home the guages stoped working for the rpms, gas, speed everything and battery died is this normal with the battery just dieing or do i have 2 problems? i didnt have time to mess with anything yet until later today.
Old Jan 1, 2011 | 12:12 PM
calif phil's Avatar
Most likely the Alternator is not working. You need to charge your battery and then check the voltage while the truck is running. You should see about 14 volts. If it's only 12 volts or so them it's alternator time.
Old Jan 3, 2011 | 05:48 PM
mach1nm's Avatar
Alternator showed good. Replaced battery samething
Kevin Lawson
Feb 19, 2013 11:03 AM
TheEdge
Dec 17, 2012 11:55 PM
Muddydawg75
Aug 20, 2011 10:03 AM
barowner
Dec 29, 2010 02:08 PM
HummerGuy
Sep 8, 2006 04:05 PM
