Auto Day Night Sensor And Daylight Saving Time
Old Nov 16, 2024 | 04:54 PM
oceanbrave's Avatar
Is it possible to put a cover over the sensor to block out the light?
Old Nov 16, 2024 | 05:05 PM
PGI Conch's Avatar
Of course. Black electrical tape or silicone any small black cap that fits over it. Headlights will remain on unless switch is turned to off position.
Old Nov 16, 2024 | 06:22 PM
BLK WLF's Avatar
You can also pop the sensor out the dash and bypass the sensor with a wire and you just have a on and off switch with the auto switch.
Old Nov 16, 2024 | 06:56 PM
That's the correct way to test photocell sensors in bright day light!
You could also test by driving through a road tunnel.
Old Nov 17, 2024 | 07:21 PM
Mark R's Avatar
That won't work...Unless the Tunnel is long. The GM Ganja Tech-ies built a delay in the system in case you go thru a short tunnel. Best way to test is with a dark cover and a stopwatch. Time it. Or have your wife or Girlfriend smear some eyelash goop on there while your doing 99 MPH.
fastNYsix
Sep 3, 2020 01:59 PM
chevykev
Mar 27, 2019 09:51 AM
Shale
Oct 20, 2014 07:16 PM
26sonic
Oct 14, 2012 01:47 PM
JM
Jan 30, 2007 03:02 AM
