any one else get wind noise/vibration on roof
Old Mar 7, 2018 | 03:33 PM
ENASNI's Avatar
Default any one else get wind noise/vibration on roof
I get a vibration on both sides of the roof right above the wind shied any else experience this? Nothing is loose. I'm thinking ill just fill the plastic trim with black silicone unless some one found a better solution. My 08 H3 had the same issue, maybe it's a Hummer thing. My current truck is a 05 H2T.
Old Mar 25, 2019 | 06:55 PM
maine_gunner's Avatar
I had a noise that sounded like a vibration from the roof on the passenger side. I took off the windshield molding that goes up the side. Put some foam tape on it reinstalled it and it seems like the noise is gone you might want to give it a try
Old Mar 26, 2019 | 10:48 PM
LoJac963's Avatar
Long running issue, search is your best option. Remove the side windshield plastic, install new double sided sticky foam or whatever you want, reinstall.
jonnieh3
Mar 2, 2016 11:59 AM
elron
19
Mar 28, 2010 12:28 PM
flrtrader
Nov 2, 2009 07:24 PM
finskeeper
Mar 20, 2007 02:58 AM
mitch1
17
Mar 20, 2006 02:56 PM
