Annoying beeping/ringing noise ignition key?
Old May 29, 2022 | 05:15 PM
flashinq's Avatar
Default Annoying beeping/ringing noise ignition key?
The noise in the video linked I hear when just one turn at the key and at all times when H2 is running. Please help?
https://youtube.com/shorts/pjHhCmcNKhI?feature=share
Old May 29, 2022 | 08:25 PM
try lubing the ignition cylinder or get a new key made and see if it continues. if they say they cant make a key for a hummer tell them that you need it for an escalade, suburban, taho, or a 2500 same chit. had that happen at home depot. 2 bucks later the truck started.
Old May 31, 2022 | 10:18 PM
flashinq's Avatar
Default Figured out?
I was lifting up my rear seats and heard the ringing get louder and saw this circuitry device and heard the ringing coming from it and it had a off switch and i clicked it off and bam no ringing. Is this something I need? never seen it before.
Old Jun 1, 2022 | 08:40 AM
Not really, at minimum you would want to make sure it is always turned off unless you are using it as AC inverters do tend to draw a good bit of power from the battery. That inverter will provide a 120V AC plug outlet on the end of it which you can use to power a laptop charger or maybe a portable DVD player of smaller game console for example. At 150w it is pretty small though so not enough power to run a coffee maker or power tools. My guess with the other cables is a prior owner rigged it to run a game console or portable DVD player for kids.
The other wires are A/V (left and right audio plus composite video) extensions for connecting said game console or portable DVD player to connect to headrest monitors or maybe a swing down ceiling monitor.
esfop319
Dec 3, 2019 03:53 PM
stoneman
May 7, 2018 01:41 PM
sakodik
Sep 29, 2013 11:20 PM
djslickrick
Nov 10, 2011 09:21 AM
lwolny
Sep 16, 2007 04:03 PM
