ampli bose hummer h2
Old 03-07-2017, 11:56 AM
Carlos Fernandez's Avatar
Default ampli bose hummer h2
hi all, i have a hummer h2 2008 model 6.2
the radio work but no sound i think the ampli bose is broke , but i can't find it
where is located?
thanks
Old 03-07-2017, 01:02 PM
Not easy to get at..... its mounted underneath the back part of the center console. I think you have to just about remove the entire center console to get to it. I'd strongly suggest looking around online for the GM 05-09 esi download from somewhere. Its the GM service info system / electronic service manual.
First I'd check if you just have a blown fuse somewhere though. Yours is different than my 2003 though so I'm not sure on yours. I know on my 03 there are a couple of different fuses in the under hood fuse box. One is just the Bose amplifier.
Old 03-07-2017, 02:06 PM
under the gear lever ??
Old 03-08-2017, 08:23 AM
Hummer H2 - N2(06-36) AUDIO SYSTEM/FRONT > EPC Online > Nemiga.com
This site might help you locate things. The part circled A is the amplifier. It is under the rear part of the center console.
Old 03-08-2017, 01:17 PM
thank you very much , im from italy and and here I have not found a technical know where, was the amplifier
It is not very common here hummer
grazie
mrigor
07-09-2013 11:08 PM
theBroken
10-03-2009 08:23 PM
desiyaar1
09-26-2009 09:17 AM
Mad Professor
04-18-2009 06:49 AM
RedRocker
05-03-2007 07:19 PM
Quick Reply: ampli bose hummer h2
