ampli bose hummer h2
hi all, i have a hummer h2 2008 model 6.2
the radio work but no sound i think the ampli bose is broke , but i can't find it where is located? thanks |
Not easy to get at..... its mounted underneath the back part of the center console. I think you have to just about remove the entire center console to get to it. I'd strongly suggest looking around online for the GM 05-09 esi download from somewhere. Its the GM service info system / electronic service manual.
First I'd check if you just have a blown fuse somewhere though. Yours is different than my 2003 though so I'm not sure on yours. I know on my 03 there are a couple of different fuses in the under hood fuse box. One is just the Bose amplifier. |
under the gear lever ??
Hummer H2 - N2(06-36) AUDIO SYSTEM/FRONT > EPC Online > Nemiga.com
This site might help you locate things. The part circled A is the amplifier. It is under the rear part of the center console. |
thank you very much , im from italy and and here I have not found a technical know where, was the amplifier
It is not very common here hummer grazie |
