Advice on preventing further rust
Old Jun 10, 2026 | 04:21 PM
Vax1op369's Avatar
Originally Posted by Brunob00
@Vax1op369 - Looks like this is the video? Looks like your recommendations are:
  • Rustoleum Rust Dissolver
  • Eastwood Rust Encapsulator Plus
Yea man, I have video on tools as well. Die Grinder , angle grinder, wheel grinder. Tools, Eastwood spray paint and paint about $1,000 to do it right. Good time to upgrade u joints, fuel pump and trans module.
Old Jun 10, 2026 | 06:44 PM
A
needle scaler needle scaler
speeds up the process.
Old Jun 10, 2026 | 09:32 PM
Hummthere's Avatar
great video Brunob00
Old Jun 10, 2026 | 09:48 PM
Hummthere's Avatar
another thing I plan on doing is removing the top rack and plastic as well as the lower bottom trim/ plastic and brush on encapsulator 2-3 coats then maybe a coat of paint ( bottom) on the top 2-3 coats of encapsulator like I said but when its all good and dry I'll probably cover the sealer with a tape called Zipp tape ( its used on construction sites ) and when its on - its on there ! and its smooth so dirt etc should run off . its the best tape Ive ever seen and also holds up to heat - It can be used to seal seams under tin roofs so should hold up pretty well
Old Jun 11, 2026 | 09:11 AM
Vax1op369's Avatar
yea that’s it, check out my playlist for rust
Hummerh22
Jun 11, 2026 09:50 PM
BlueH3
Sep 4, 2020 04:32 AM
Nelly82
Aug 28, 2017 04:07 PM
nelsonhood
Sep 4, 2013 10:37 AM
ultraclassic01
Jan 2, 2012 12:23 AM
