ABS and TC/ light came on after wheel spin on snow
Old Jan 10, 2020 | 12:52 PM
apollo18's Avatar
Default ABS and TC/ light came on after wheel spin on snow
Hey guy 2003 hummer h2 and we had a large snow storm a couple days ago and I hit a patch of snow, and lately when I hit a patch of snow I always tend to hit the pedal more to get a little wheel spin and have some fun but I guess maybe I spun a little too much? Because once I passed the snow patch I got the abs light and tc / light illuminated. It never shut off but I just got to work so I will see when I get back to the truck in the evening if it’s gone by itself.
what do you guys think it is? Do you think maybe I just overloaded the module or something and a negative battery pull will fix?
thanks
Old Jan 10, 2020 | 02:32 PM
apollo18's Avatar
Also let’s say if it doesn’t go away with the restart/battery pull. Is it really bad to drive in winter without ABS and TC? I would be getting it fixed within a week tho
thx
Old Jan 10, 2020 | 03:11 PM
That is usually caused by one of the wheel speed ABS sensors getting damaged.... ABS and traction control are generally good things to have working.
Edit to add - might actually be fine but I think it takes like 100 ignition cycles for the codes to self clear. Otherwise you need a code reader that can clear codes (might have to be a Tech2 for that code but I'm not sure on that).
Old Jan 10, 2020 | 04:17 PM
Go to your local auto parts store and get a free scan, post the code.
Old Jan 12, 2020 | 07:05 PM
apollo18's Avatar
lucky me!! it went away after a couple ignition cycles
Old Jan 12, 2020 | 07:27 PM
You can scan for codes to find the source and correct, or you can make believe that you have a self healing robot.
AKDropm
Aug 2, 2012 11:07 PM
Rusty_03
Nov 5, 2010 08:47 PM
moto.racerx
25
Oct 30, 2010 06:45 AM
Rusty_03
Jan 26, 2009 11:56 AM
Intercooled
Aug 8, 2005 10:04 PM
