3rd battery in 4 month
Old Jun 28, 2021 | 03:06 PM
Hummerrican's Avatar
Angry 3rd battery in 4 month
I'm sure this is a very common question, but again.
My H2 kill 3 batts in 4 month, obviously, no more batt warranty. During this time, I make a couple of tests and radio, radio amplifier, car lighters, washer pump, power locks, SOS system fuses are disconnected, but last night it killing the batt.
Any of you has starter, alternator, power seats, power mirrors or wiper motor issues that drain the batt?
Any help will be really appreciated.
Old Jun 28, 2021 | 04:42 PM
Old Jun 29, 2021 | 07:29 AM
calif phil's Avatar
My 2003 had an intermittent battery drain, turned out to be the ignition switch, the key would come out but the switch would not shut off the power and battery dead over night.
Old Jun 29, 2021 | 08:31 AM
Need to do a parasitic battery draw test and figure out what is staying powered.
Old Jun 29, 2021 | 03:02 PM
update:
set the multimeter in line with the H2. Instantly, the reading was 0.682 Amps, but after 30 to 40 secs, it drops to 0.002 Amps.
So, I don't understand what is happening.
Still looking
Old Jun 29, 2021 | 03:18 PM
Originally Posted by Hummerrican
update:
Still looking
You need to monitor more than 30 to 40 seconds. Grab a beer and monitor the cycle, while pulling fuses.
Old Jun 29, 2021 | 05:02 PM
Also search here on the forums for parasitic draw. I've posted some time back a document from GM that details that test on an H2 and states how long it takes for certain modules to "sleep". Also, if your Onstar is no longer used, definitely remove the fuse for it as that is a known culprit, especially if it is an early analog one (continually searching for an analog cellular signal as well as satellites for GPS). I believe that is the VCIM fuse in the underhood fuse box if I remember right.
Old Jun 29, 2021 | 07:12 PM
Stevegt17's Avatar
My hummer had a tracking system installed. I can’t remember what it was called but it is now owned by lo lack. My truck battery would drain all the time. Once I removed the tracking system and stopped buying batteries from gm my truck battery had never died.
Old Jul 4, 2021 | 10:49 AM
finall's Avatar
@Hummerrican
There will always be a tiny draw. That is to keep the electronic memory going, like clock, etc. So the 0.002A you are seeing is likely correct.
The initial higher reading was likely your courtesy lights.
Looks normal to me.
Old Jul 4, 2021 | 08:56 PM
are you sure the alternator is not overcharging the battery and boiling them?
Mike Leggero
Hummer H1
Jul 15, 2020 01:28 PM
newh2owner
Sep 7, 2017 03:51 PM
CurtisP87
Oct 9, 2014 02:21 PM
Linda
Oct 20, 2009 08:10 PM
shmoney1
Feb 26, 2007 04:59 PM
