Battery keeps draining
Old Jun 7, 2020 | 07:06 PM
Mike Leggero's Avatar
Default Battery keeps draining
2002 H1
My batteries are draining. I probed each fuse and all of these have power when the key is off
Should any of them not have power with the key off.
Trailer brake
Aux power outlets
Aux batt terminals
Power locks
Radio clock
ALDL RKE
Compass mirror
Hazzard flasher
Brake lights
Cigarette lighter
Fuel pump PCM
Radio battery
ABS
Horn
Windshield
Windshield
Ignition
ABS pump
CTI
Windows
HVAC
Lights
Lights
Starter
Old Jun 9, 2020 | 12:43 PM
Paranormal's Avatar
Before driving yourself crazy, check the battery terminals and cables. Corrosion builds up inside the caps that cover the terminals and prevent a good contact. This is the very first thing that I had to do several years ago when I first purchased my truck. Take it apart and clean them out real good with a wire brush. Even replace the bolts if you want. They are cheap.
If you're certain that you have a drain, start by checking any extra stuff that may have been added to the truck. Like alarms or aftermarket stereo
Old Jun 22, 2020 | 10:59 PM
V-tek's Avatar
have you checked how many amps you are drawing while sitting? What other toys do you have hooked up? I check mine for a parasitic draw and all the standard equipment was good, but I found out the largest draw was my ScanGauge that I have plugged into the OBD II port. I think with everything there was a .1 amp draw. Plus I had a battery that was starting to go out after 3 years, should have lasted longer. Now with new batteries I have no problems even if I only drive it once a month.
Old Jul 15, 2020 | 01:28 PM
ElDiablo Adam's Avatar
I'm not an expert but my 03 has all cigarette plugs live and the interior lights never go to sleep unless you close all doors.
loud pipes
Sep 5, 2020 07:21 AM
Zeppelin
Sep 29, 2018 09:47 AM
newh2owner
Sep 7, 2017 03:51 PM
Husa4342
Apr 28, 2015 07:48 AM
kramcard6
Feb 24, 2015 10:32 PM
