View Poll Results: What would my option for best tires and rims ?
Bf Goodrich all terrain with rhino rims
50.00%
Cooper all terrain with rhino rims
0%
Bf good rich all terrain with method rims
50.00%
Cooper with method rims ?
0%
Voters: 4. You may not vote on this poll
37” / 13.5 / 17 tires all terrain
Old Aug 13, 2025 | 09:50 PM
Fahollywood's Avatar
Default 37” / 13.5 / 17 tires all terrain
Hello,
I am putting in a 37” / 13.5 / 17 on my 2006 Hummer H2 SUT, I would like to purchase some rims as well but what my offset should be so I can avoid the wheels from grinding ?
Old Aug 15, 2025 | 07:40 AM
calif phil's Avatar
My vote is BF Goodrich or Goodyear Duratracs on stock wheels.
Old Aug 15, 2025 | 02:46 PM
Gavin Costigan's Avatar
Originally Posted by Fahollywood
Hello,
Contact the company you buy the wheels from they’ll tell you whether or not they’ll fit.
Old Oct 2, 2025 | 07:45 AM
Beachrider99's Avatar
Dodge power wagon offset
Old Oct 6, 2025 | 12:16 PM
Brunob00's Avatar
I don't believe you can put 37s on the H2 without rubbing in the front and reducing wheel travel in the back. In general 37s need a lift. The H2 can support up to 12.5 without modifications, but I believe 13.5 will rub in the front.
Others can weigh in but I believe the perfect fit for the H2 is:
* OEM = 315/70 R17 - BFG KO3
* or 35x12.5 then pick your wheels... R17, R18, R20
Everyone has an opinion on tires... if you do highway miles, I highly recommend the General Grabber AT/X as they are very quiet. The BFG KO3 is very highly rated (9.1 on tirerack)
If you like the Rhino black wheels then also check out XD. Here is a Black Rhino review -
Some Method models offer greater bead grip for off-roading, it may be the wheel if you offroad -
Most other options need trimming or a lift, or they rub. Checkout Custom Offsets
I do see that someone on Custom Offsets says that FUEL BLITZ 17X9 with NITTO RIDGE GRAPPLER 37"X12.5" do not rub... probably because they are on 9" width wheels - which I am not sure is optimal if you air them down for off-road... would much rather have 10 inches there.
What I like about Custom Offsets is you get feedback directly from other H2 owners... and they allow you to filter tires setups based on whether you need to lift, trim or if there will be rubbing. When looking at wheel/tire packages, there is a button called "See What Others are Running" which is helpful as well. Their website will also recommend the right offset... as would Tirerack...
Old Oct 13, 2025 | 11:17 AM
If you like the Rhino black wheels then also check out XD. Here is a Black Rhino review - https://youtu.be/upeR_LAs55cSome Method models offer greater bead grip for off-roading, it may be the wheel if you offroad - https://youtu.be/s529iqluBlk?si=gEX-ELqD4pBJvUUN
I run 37x13.5r20s on a 10 inch wide wheel. Don't know what the offset is, but I have full suspension travel front and rear with only rubbing on the frame and back fender liner at full lock. Only with a front level. It actually fit just fine when front was stock height too.
Old Oct 13, 2025 | 11:28 AM
Brunob00's Avatar
Kevin - Can you post a photo, and which tires are you running?
Old Nov 30, 2025 | 03:07 AM
kailons's Avatar
Default Criação de sites
A criação de sites tornou-se um dos pilares essenciais para qualquer empresa que pretende destacar-se no ambiente digital. Mais do que uma simples presença online, um site profissional funciona como o cartão de visita moderno, capaz de transmitir credibilidade, atrair clientes e impulsionar vendas. Hoje, os consumidores procuram informações rapidamente e valorizam marcas que apresentam websites rápidos, intuitivos e visualmente apelativos. Por isso, investir num site bem estruturado é uma estratégia que impacta diretamente o sucesso de qualquer negócio.
Um bom processo de criação de sites envolve planeamento, design funcional, conteúdos claros e optimização para motores de pesquisa. É fundamental garantir que o website seja responsivo, seguro e fácil de navegar, oferecendo uma experiência positiva em qualquer dispositivo. Além disso, integrar ferramentas de análise, formulários de contacto e chamadas para ação aumenta significativamente as oportunidades de conversão.
Para obter resultados sólidos, é recomendável recorrer a especialistas. A Webis Agência destaca-se como uma referência na criação de sites profissionais, combinando tecnologia, criatividade e foco em performance. A sua abordagem estratégica permite desenvolver websites capazes de reforçar marcas, melhorar posicionamento e transformar visitantes em clientes. Apostar num site profissional é, hoje, um investimento indispensável para crescer no mundo digital.
Old Dec 1, 2025 | 09:37 AM
SHOCKTROOP40's Avatar
I'm not sure what the offset of the wheels I had on my first H2, but I was running 38 x 13.50 R20's on mind.
hakan
Mar 28, 2018 07:32 PM
HARDxCOR3
Oct 3, 2012 03:48 PM
jwat142
May 16, 2011 07:28 AM
spusoccer
Jan 7, 2011 08:52 AM
HummerUAE
Dec 19, 2007 06:35 PM
