2005 H2 Pass side Leak "stumped"
Old Mar 2, 2023 | 05:35 PM
jhall's Avatar
Default 2005 H2 Pass side Leak "stumped"
So i was having leaking issues on the passenger side floor.....i took the cowl off and resealed the plastic door that exposes the blower motor....i thought i had the leak fixed but apparently water is still getting into the airbox blower motor area...there is even water on my blower motor resistor ....not exactly sure where to look now....i thought that black plastic cover under the cowl was the only source for water to get into that motor/resistor area....somebody tell me what i missed as i am sure i'm not the only one ...fyi...thats the only area on the passenger side that water is getting in....no water under sill plate on pass side...it's dry....it's coming in somewhere around the resistor/ motor area?????? please help...i've checked the SR drains...the door weatherstrip ...no water at all in headliner or down the A pillar
Old Mar 3, 2023 | 10:47 AM
did you check to see if the condensate drain is plugged maybe back filling into the cabin? or loosing small amounts of coolant and don't know where its disappearing to ? like heater core weeping starts. another thing to look for is the sunroof drains, they drain behind the firewall and the heatshield and can cause rot holes into the firewall toe board area where the shields attach too
jhall
Feb 17, 2023 01:46 PM
Dieseldrums
Mar 7, 2015 07:34 AM
jsbihn
Feb 1, 2015 03:53 AM
hmer
Sep 21, 2014 02:29 PM
h2 canonman
Mar 20, 2013 03:12 AM
