2005 H2 Blinking engine light, O2 sensor and Cylinder H codes
Old Jul 6, 2020 | 12:08 PM
Daniel Z's Avatar
Default 2005 H2 Blinking engine light, O2 sensor and Cylinder H codes
Looks like the codes are for Cylinder H (8) ignition coil and O2 sensors. Question, should I change all of the ignition coils or just this one?
drove the truck and noticed some vibration and loss or limited power when accelerated. it would gain speed eventually.
Check engine light was blinking but at light it went to solid light, then drove and switched to blinking again.
Old Jul 6, 2020 | 01:25 PM
tharber's Avatar
Check spark plug and wire first. Then if they look OK, just take coil pack from cylinder next to it and see if the problem is still there.
Tim
Old Jul 6, 2020 | 01:28 PM
exhaust manifold leaks can also cause Oxygen sensor codes. maybe you have missing bolts. look for black soot near the number 8 plug.
JORO9
Jul 22, 2019 12:31 PM
dan385
Jul 22, 2018 08:57 PM
finall
May 6, 2017 08:50 PM
Diablito
Sep 1, 2013 01:00 PM
badboyz67
Dec 24, 2007 07:49 AM
