Oxygen Sensor Unplugged
Old Feb 8, 2018 | 10:58 AM
JORO9's Avatar
Default Oxygen Sensor Unplugged
I recently bought a 2006 Hummer H2 SUT.
The check engine light was showing oxygen sensor 2/ bank 2. I took it to my mechanic and he said it was unplugged. He fixed it and the light went off. 1 hour after driving it from the mechanic's the light came back on and was diagnosed as a random misfire. Could unplugging an Oxygen sensor bypass any other codes on the vehicle?
Last edited by Doc Olds; Feb 9, 2018 at 08:13 AM. Reason: No reason for a hyper link off "check engine light"
Old Feb 9, 2018 | 08:16 AM
The answer is NO.
If you persist in links to other forums it will be considered spam, and you will be treated as a spammer.
Old Jul 22, 2019 | 08:31 AM
Andrea Tyson Morris's Avatar
I have the same issue and would like to know the outcome of your H2 and the catalyst converter Bank 2.
Old Jul 22, 2019 | 12:31 PM
there are sequential steps the the ECU takes to trigger a code. so if there is an error it will show the most severe one until it gets corrected then continues to the next code. so very common that another code will develop if there was more than one issue going on at the time. in the case of the misfire the ECU could not determine the misfire as it needed the O2 sensor to determine the misfire.
jman1335
Oct 20, 2017 09:05 AM
2005H2
Dec 14, 2016 06:07 PM
JRAguilar
Apr 6, 2012 07:45 AM
