2003 hummer h2/driver side seats
Old Dec 28, 2019 | 10:20 AM
sean04h2's Avatar
Default 2003 hummer h2/driver side seats
Hello H2 enthusiasm
is there anyone had any experience of having issues with seats not able to go up an down? mine just making some cranking noise but doesn't go up anymore, it slides back an fort though.
Fernando
Old Dec 29, 2019 | 08:19 PM
if it is making noises then you need to check the motor to see why,
Old Dec 30, 2019 | 05:57 AM
sean04h2's Avatar
Default Driver seats not going up n down
Thank you for responding.
I remove the seat and it seems that the motor is bad. Just trying to find we're I can buy that motor and also trying to learn how to remove it it's seems very complicated.
I have attach a photo.
thannks again.
Old Dec 30, 2019 | 06:00 AM
sean04h2's Avatar
Default Driver seats motor replacement
Please help..anyone had replace this motor before? How? Thanks
Old Dec 30, 2019 | 03:06 PM
On the upper one in the picture it appears as though the metal motor housing has tabs bent in to attach it to the small gearbox. I'd double check that you get power to the connectors on each motor with a meter before you do anything just to be sure. Somewhat rare for an electric motor to fail in this sort of very light and momentary usage scenario.
I'm betting GM did not sell just the motor as a separate part. Likely the entire lower seat track assembly....
Old Dec 31, 2019 | 06:17 AM
sean04h2's Avatar
Old Dec 31, 2019 | 06:48 AM
Just checked out of curiosity..... yep. One entire big part. Same "adjuster" is used in a few of the earlier full size SUV's as well. On sale for just $870.00 https://www.gmoutletparts.com/oem-pa...track-19127251 lol
Personally I'd be figuring out out to take it apart and fix it myself.
Old Jan 1, 2020 | 06:40 AM
sean04h2's Avatar
I did find 1 on ebay for $290
but i wil take it to the shop first and see if they can test it might be just wiring issue? I'm really low on knowledge fixing cars.
I do have 2, H2 and I love them.🙂
Thank you.
bsucpa
Aug 11, 2013 01:37 PM
basic123
Nov 4, 2011 12:28 AM
JDTDBD
Mar 26, 2011 05:19 PM
DHolli
Feb 23, 2010 06:23 PM
hawknthasky
Oct 27, 2009 07:36 PM
