2003 H2 ABS, TC, Service Brake System
Old Feb 6, 2023 | 01:41 PM
  #21
does it work if you put the old fuse box back? if so make sure all the fuses and relays are where they should be on the new one and check the new fuse box for bent connector pins.
Old Feb 6, 2023 | 02:40 PM
  #22
the Milenko's Avatar
yes it did, actually this is the 2nd fusebox, the first I got everything worked except it wouldn’t start, put old back on it started, took it to GM they honored it gave me another one now scanner will not connect
Old Feb 6, 2023 | 10:40 PM
  #23
well then check what i mentioned above.
Glennc6
Jan 21, 2020 03:54 PM
Chillywilly
Jul 23, 2019 11:41 AM
bryanw
Apr 4, 2015 03:54 PM
bryanw
Apr 3, 2015 07:48 PM
sysco1hummer
May 24, 2011 08:55 PM
