09' H2 Axle gearing issue 5.13's
Old Mar 13, 2025 | 12:31 PM
legerwn's Avatar
the gears are coated with a phosphorous coating to facilitate break in so its critical to change the break in oil at 500 miles, if I remember correctly or trucks require synthetic oil for the diffs.
I typically use Amsoil in all my stuff
Neal
Old Mar 16, 2025 | 12:16 PM
CaboDave's Avatar
Update:
Received the truck Friday afternoon. Everything was in great condition, I'll bring it back at 500 miles for an inspection and fresh oil.
Old Mar 21, 2025 | 11:14 AM
Gavin Costigan's Avatar
Originally Posted by CaboDave
Update:
Wouldn't worry too much about it. If its good in that 500 miles, you'll likely never have an issue. Rest of the drivetrain will be fine being drug a little too. Just keep an eye for any leaks. Usually these diffs leak out of the outer axle seals until they weld themselves together because no one notices.
Old Mar 23, 2025 | 09:53 AM
H2-SUT's Avatar
Remember the front diff is a little fussy as far as fluid, Put in to much and you will find diff oil slinging out of the axle seals. Some like to fill them way past the level of the plug, not a good idea,
kmo233
May 5, 2017 09:33 AM
hrcentury21
Dec 7, 2015 12:06 PM
Jman1928
Jan 27, 2012 09:02 AM
Greenblade
Mar 29, 2007 04:18 PM
importkiller
Dec 25, 2006 04:57 AM
