05 H2 Battery Drain, any thoughts?
Old Jan 13, 2023 | 12:53 PM
Vax1op369's Avatar
Default 05 H2 Battery Drain after few hours, any thoughts?
New Battery.
No after market accessories.
Pulled on star fuse, still drained after sitting for 5/6 days. Should i pull out the on star unit?
Gone through lots of posts. Recommended shut off factory alarm and shutting off light switch override. Are these options in the DIC menu? I did buy all new glo fuses to replace all the fuses, would that help out at all? Thank you everyone.
Old Jan 13, 2023 | 07:09 PM
for me it was the dealer installed XM radio module that was draining the battery. it was not working properly when i purchased the truck. removed the module and its wiring and my problem went away. i was getting a u1000 code on the scan tool and it would not see the XM unit. thats how i located the issue.
Old Jan 13, 2023 | 08:57 PM
Vax1op369's Avatar
Default H2 Battery Drain after few hours, thoughts?
thx im working on getting out the on star. Read that it still drains even after fuse is pulled.
OBIrishman
Sep 17, 2022 09:19 AM
luke1213
Sep 15, 2016 07:18 PM
E-dragon
Jan 18, 2015 01:04 PM
Kevin Lawson
Feb 19, 2013 11:03 AM
HammerDown
21
Feb 19, 2008 07:04 AM
