Constant Battery Drain
Old Jan 24, 2016 | 11:44 AM
luke1213's Avatar
Default Constant Battery Drain
What could be causing the battery to be draining all the time? If my truck sits for more than 4 days, the battery is dead. The battery is about a year old. I've had the battery tested and it's good. Any ideas?
Old Jan 24, 2016 | 01:38 PM
Ian Ward's Avatar
Corrosion on battery will cause surface discharge and slowly drain your battery. You most likely you have a load on a circuit causing the battery to drain (pulling power constantly). Test the battery voltage ,Unplug the main fuses one at a time. When you pull a fuse and the voltage stops dropping it is in that circuit. I would start by checking aftermarket electrical wiring- accessories and alarm.
Old Jan 25, 2016 | 07:41 AM
FlyingArmy's Avatar
Check your alternable cables for corrosion too. Have your charging system checked. This beast has an inherent residual drain on batteries. That's why I installed a Battery Tender Solar panel on the roof. I was having the same issues and haven't since I installed the solar panel. It's just a solar trickle charger. Hope that helps!
Old Sep 13, 2016 | 11:43 AM
PapaKen's Avatar
Default battery drain
My 06 H3 had battery drain problem, turned out previous owner had broken cd off in cd player, this was the problem! removed broken cd, problem solved!!
Old Sep 14, 2016 | 08:01 AM
calif phil's Avatar
My 2003 had the same problem and it was the electrical portion of the ign switch.
Old Sep 14, 2016 | 11:25 AM
madmayo's Avatar
I was having this issue as well. Make sure when you turn the key back to remove it you have it turned all the way back. My key can be removed with a 1/16th left in the rotation. If i dont turn it all the way back the battery light will stay on and drain the battery. I bought the new electrical part of the ignition switch but haven't installed it yet. I think it was around $57 from the dealer.
Old Sep 15, 2016 | 07:18 PM
flyday58's Avatar
Aftermarket stereos and alarms have also been identified as battery killers, depending on who or which shop did the installation.
Mad Professor
Jan 16, 2025 08:13 AM
AztecH2
Aug 4, 2012 01:53 PM
patricktheelder
Jul 4, 2010 05:46 PM
motley1987
Mar 13, 2010 03:25 AM
extralims
Apr 27, 2009 12:51 PM
