!*!*! Visor !*!*!
Old Feb 9, 2024 | 01:44 PM
BLK WLF's Avatar
Default !*!*! Visor !*!*!
Got myself a visor wing for front windshield on the H2.
Finished it with the raptor liner treatment same as the hummer.
it came with the cheapo DRL’s.
So I ordered the blacked out Cree leds in white and amber.
Now I can’t make the decision if I should go with amber (I do already have the upgraded smoked lens amber lights on the roof) or should I go with the white?
Amber……. or White……
Old Feb 9, 2024 | 03:10 PM
Amber is outdated and with less lumens.
Just make sure to properly secure/waterproof, I use
solder seal heat shrink waterproof butt connectors solder seal heat shrink waterproof butt connectors
, and run wiring parallel.
Old Feb 9, 2024 | 04:15 PM
BLK WLF's Avatar
Just make sure to properly secure/waterproof, I use solder seal heat shrink waterproof butt connectors, and run wiring parallel.
https://youtu.be/tZOoBr4ghrw?si=LsR9S9naZHXLfd7D
Yes of course soldering and with a shrink wrap.
w
The main wires are all in the visor ready, all I need to do clip the cheap LED’s out and solder the new ones in.
I think you’re right that amber is old school.
Think it will look solid if I go with the blacked out white.
Thank you sir for the info again.
Ben.
Gavin Costigan
Sep 15, 2021 08:56 PM
DougandBeth
36
Dec 30, 2009 08:15 AM
FloridaFeMan
Nov 5, 2009 07:22 PM
w3sCiH3
22
Mar 5, 2008 03:38 PM
littlehummerboy
16
May 27, 2007 10:14 PM
