!*!*! Lift !*!*!
Old Sep 22, 2024 | 06:34 AM
BLK WLF's Avatar
Default !*!*! Lift !*!*!
The H2 is going the distance but in height.
A LCS here quoted out a lift kit for my H2 and there were only two made as of today, a 7” lift and a 6” lift.
I just want a 3” to 4” lift as I don’t need much as my new tires are rubbing just a little when backing up.
Now if I have to go 6” so be it but I haven’t checked with you guys yet if there is a 3” to max 4”
kit in the land of H2’s.
Oh, 2008 H2 SUV, 77k miles,
Old Nov 11, 2024 | 09:24 AM
jsbihn's Avatar
As for lifts, I would suggest just getting a 3 inch lift kit, which is spacer pucks for the rear springs, 3 inch key lift for the front, new pads for the rear pucks, and new longer travel shock all the way around. Easy to install, cheap and does the job.
I have 38s on one of my H2 with the same lift setup.
It looks great and the ride is great too
*** side question for you, where did you get the raised hood vent? That thing is pretty killer.
Old Nov 11, 2024 | 09:55 AM
BLK WLF's Avatar
Thank you.
I haven’t done the lift yet so all info is still welcome.
As far of the hood scoop I got it on eBay, took about a month to get here but that gave me time as what LEDs to use as I didn’t want to have China LEDs that will leak, collect moisture or be brighter than they say as only 300 lumens are street legal.
Old Nov 12, 2024 | 11:06 AM
jsbihn's Avatar
Thanks for the info.
yeah i bought the supreme suspension setup. It worked for my rig. I have 38s on my setup and i barely make contact, i think i only touch is when i am going at speed and i try and make a turn at full lock +
Old Nov 12, 2024 | 12:11 PM
BLK WLF's Avatar
Do you remember from who you got the supreme suspension setup/lift?
Old Nov 13, 2024 | 07:05 AM
jsbihn's Avatar
I am pretty sure it was purchased from either Supreme Suspension themselves, or Amazon
As for the extended shocks, they are SkyJacker. I bought them from (again) either SkyJacker, or Amazon
Sorry I couldnt be more helpful with the "where i bought them at" questions. It has been at least 10 years since I installed them.
Hope this helps
Old Nov 13, 2024 | 12:09 PM
BLK WLF's Avatar
Hope this helps
More than enough, thank you and happy hummering.
Old Nov 19, 2024 | 11:26 PM
Gavin Costigan's Avatar
I bought adjustable index keys from suspension maxx. You can index them in 1” increments. Really handy for when my replacement lower control arms from o’reillys were indexed incorrectly. Like 2 inches off. All I had to do was set the index on the key.
Old Nov 23, 2024 | 07:13 PM
BLK WLF's Avatar
Thank you.
I’ll like that option.
Hmmer
Mar 24, 2013 09:17 PM
sa24
Feb 22, 2013 02:24 PM
sa24
Feb 22, 2013 02:21 PM
kouvelis888
Jan 25, 2008 11:50 AM
kouvelis888
Jan 16, 2008 12:19 AM
