New member, Need help with transmission shift issue
Old Nov 30, 2022 | 01:31 AM
AKhummerh1's Avatar
Default New member, Need help with transmission shift issue
Hello All, im new to this forum and I am fully restoring a 1995 hummer h1 with a 5.7 GAS engine TBI.
A little background:
I modify exotic cars for a living so I am pretty mechanically inclined, however I am not a mechanic.
so the car came to me not running, turned out to be a simple fix (drain plug in gas tank was toast so tank was empty (haha) I also rebuild the throttle body with new injectors. and she runs! I tore the care down completely and sent it out to Line-x for a full liner and re assembled the car with every single part brand new. so she looks GOOD.
As I never driven the car more than just around the block a few times after getting it running, I don't really know if the problem was there before or not. but I do not feel like it was.
long story short, the car will not shift, just stays in one gear (assuming 2nd) I removed and cleaned the speed sensor (will replace soon after getting some input). Fluid is good.
My question is (and I've searched for days) would a disconnected speedometer cause the transmission to not know vehicle speed, thus causing the shifting problem.
I put all new speed hut gauges and the speedometer works off GPS and is not actually connected to the VSS signal.
any input would be greatly appreciated as I don't want to just throw new parts for no reason.
and no intro is good without photos!
Old Dec 1, 2022 | 06:18 AM
abner1951's Avatar
there is two sensors on transmission that the hummer h1 uses them both. Has this transmission been changed or is it original to truck
thx
Old Dec 1, 2022 | 11:49 AM
AKhummerh1's Avatar
thx
as far as I know its original, nothing looks out of the ordinary or modified. however looking under at the two sensors there was a previous hack job on the wires for those sensors. (will post photos) I temporarily re did the wires to see if it would fix the issue as the old wires were melted and in rough shape I was suspecting a short. (maybe a short happened while I was tinkering with the wires and caused a fuse or the sensor itself to go bad? however it did not fix the problem. also I noticed one sensor on the transmission that is not plugged in and does not even have wires, or a plug, to plug it back.
the only issue is I don't believe the car has this issue when it came to me as I remember going down the street at 60mph comfortably and now I can't even touch 50mph without feeling like the engine is going to blow. it is either a coincidence OR it has something to do with me changing the speedometer?
if I can rule out the speedometer causing this I will go ahead and change both those sensors.
Old Dec 5, 2022 | 05:39 PM
AKhummerh1's Avatar
will be taking it to a reputable repair shop tomorrow so they can scan it. (obd1 with obd2 connector) my obd2 scanners all do not communicate with the car.
really hoping the speed sensor just took a crap on me coincidentally while I was working on it. rather than the speed hut speedometer and rpm gauge causing the problem
any input would be greatly appreciated.
Old Feb 2, 2023 | 05:13 AM
KingAssphalt's Avatar
Default Trans shift issue
Sir I have this same issue and have spent over $1500 trying to solve this puzzle. I've had my military H1 for over 2 years and finally I had to put it away in my storage before I put it out in the street **** on it and set it a fire. I've several transmission shops look at it. If you have had some luck with getting your issue resolved I sure would like to hear what it was. Sounds like it is the same thing. Not positive but it sure sounds the same cuz I did just about everything you did and more. Anyway, I sure would like to get old Betsy out of the storage and go for a rip. Good luck. My email address is kingpin2000@me.com if you want to contact me directly. Take care. Kelly P Fort Worth, TX
Old Feb 3, 2023 | 07:00 AM
Call Mike Sabaresse at Tustin GMC. He is the finest H1 mechanic in the country and also works on a lot of HMMWVs.
ojh32008
Oct 22, 2023 01:14 PM
steamboatrock
Jul 29, 2020 01:01 AM
NFS
Jul 18, 2019 04:37 PM
Nate2106
Dec 25, 2014 09:50 AM
HummerH2
Mar 13, 2008 12:04 PM
