H1 OBDII Scanner that can read ABS
Old 07-08-2016, 12:16 PM
sburns1967's Avatar
Question H1 OBDII Scanner that can read ABS
Does anyone have any experience with this product on a 2001 H1:
Windows OBD II Scan Tool Software - Dyno-Scan for Windows
This page indicates:
"GM Enhanced (Chevy, GMC, Cadillac, Buick, Pontiac, Oldsmobile, Hummer, Saturn)"
Enhanced OBD II
Looking for something other than the Tech2 that will read ABS easily. I know about the jumpered pin option and have used that but for $ 135
Scott...
Old 07-09-2016, 03:08 PM
HUMTECH's Avatar
That would read h2 and h3 abs data. Wont read h1 abs data. Tech 2 wont read abs data or codes either as its a standalone system with a wabco controller not obd2 compatible only way is to read flash codes using jumper at dlc.
Old 07-09-2016, 04:49 PM
sburns1967's Avatar
Thank you HUMTECH. I appreciate the insight.
Old 01-25-2018, 08:56 PM
sburns1967's Avatar
As an FYI I have determined the PIDs for reading at least the ABS wheel speed values via OBD2. So I guess there is some type of interfacing with the OBD2 and ABS sytems.
lionel90
02-12-2015 09:13 AM
djadds
09-22-2012 09:56 PM
Bullwheel
03-29-2011 05:34 AM
cisco
07-03-2008 04:37 PM
HummerGuy
03-05-2007 10:53 AM
Quick Reply: H1 OBDII Scanner that can read ABS
