H1 OBDII Scanner that can read ABS
Does anyone have any experience with this product on a 2001 H1:
Windows OBD II Scan Tool Software - Dyno-Scan for Windows This page indicates: "GM Enhanced (Chevy, GMC, Cadillac, Buick, Pontiac, Oldsmobile, Hummer, Saturn)" Enhanced OBD II Looking for something other than the Tech2 that will read ABS easily. I know about the jumpered pin option and have used that but for $ 135 Scott... |
That would read h2 and h3 abs data. Wont read h1 abs data. Tech 2 wont read abs data or codes either as its a standalone system with a wabco controller not obd2 compatible only way is to read flash codes using jumper at dlc.
Thank you HUMTECH. I appreciate the insight.
As an FYI I have determined the PIDs for reading at least the ABS wheel speed values via OBD2. So I guess there is some type of interfacing with the OBD2 and ABS sytems.
