Adding some shock mounts.
Old 07-19-2011, 09:57 AM
the gmr's Avatar
Default Adding some shock mounts.
Adding some shock mounts to this H1.
GMR designed / developed KING 3.0 bypass shocks.
Here are the mounts being designed, they are getting CNC laser cut then off to get CNC bent. Once they are done we will weld them up and onto the chassis for the shocks. I will also have pics of the shocks soon.
Jason
Old 07-19-2011, 03:23 PM
Muddydawg75's Avatar
It's like to see that as a finished product....
and I would like to see a replacement idler bracket/gusset for the H2... as well as replacement rear shock mounts....
and while I am on the kick.... a replacement panhard bracket for fabtech lifted H2's....
Old 07-19-2011, 04:25 PM
Interesting. Maybe to early to know but any idea on what pricing will be?
Old 07-23-2011, 10:29 PM
the gmr's Avatar
This setup is an in house install only on a custom application. This Hummer has been setup with an air bag instead of a spring, so the shock needs to be mounted on the side of the bag and of the arm. The mounts move the shock mounting location out so that we can fit large shocks.
If you are looking for something similar you can PM me and I can get you some pricing, but this is purely a custom setup for this specific application.
Jason
Old 07-23-2011, 10:36 PM
the gmr's Avatar
Here is a picture of the Hummer with the old shock mounts and strap mounts cut off and the arms prepped for the new mounts.
For the Front shocks I designed a specific shock length and bypass layout along with a RES outlet on the shock body. They are King Race series 3.0 bypass shocks. For the front we have a serious space restriction so I was only able to get two bypass tubes on the body. I also have welded on end caps to increase the shock stroke in relation to the overall compressed height. I will also be running 5/8" bolts for the mounts of the shocks.
The Rear is going to have a very similar shock except I was able to get a longer stroke to fit in this application. I was also able to stuff 3 bypass tubes and the RES onto the shock body making the overall packaging smaller and more compact.
Jason
Old 08-08-2011, 10:38 AM
the gmr's Avatar
Got everything back from CNC cutting and CNC bending...
Jason
Old 08-24-2011, 12:05 PM
the gmr's Avatar
finished up!
Jason
Old 01-25-2015, 10:05 AM
bigbluebronco's Avatar
was a price ever found on these? I'm very curious?
Old 01-27-2015, 07:57 AM
the gmr's Avatar
please email me for any questions, I rarely check these threads anymore.
jason@thegmr.com
thanks
jason
United Timber
05-19-2013 10:02 PM
jmoffatt
07-26-2011 03:36 AM
Fireman
09-07-2006 10:39 AM
AlanH3
07-16-2006 11:41 AM
shortbus
11-10-2005 05:34 PM
Quick Reply: Adding some shock mounts.
