General Hummer Talk Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
VXDIAG NANO Software
Old Mar 21, 2023 | 05:27 PM
legerwn's Avatar
I remember reading something on the surface pro issues and how to fix it, i'll try and find it
is there a way to turn off the touch screen function?
Neal
Old Mar 21, 2023 | 05:30 PM
jhall's Avatar
legerwn....yes...you can go into "human interface" and deactivate the touch screen....and i did that but still didnt get it to work
Old Mar 22, 2023 | 11:41 AM
legerwn's Avatar
I'm still looking for the article on the surface pro issues.
Neal
Old Mar 22, 2023 | 03:35 PM
legerwn's Avatar
what OS are you running on the surface pro?
Neal
Old Mar 22, 2023 | 03:39 PM
jhall's Avatar
Neal
it's windows 10 pro
Old Mar 22, 2023 | 05:16 PM
legerwn's Avatar
I have a laptop with 5 VM's running multiple versions of windows with both a clone MDI and the nano,
Lets look at the com ports and see if it is seeing the nano like Bronxtech mentioned.
look in device manager at the com ports and USB controllers prior to plugging in the nano then plug it in and watch for changes.
under USB controllers mine shows up as USB Serial Converter, manufactured by FTDI with driver version 2.12.36.4
under Ports it shows up as USB Serial Port (COM7) with port settings at 9600 BPS, data bits at 8, parity at none, stop bits at 1 and flow control at none
under advance settings under miscellaneous options Serial Enumerator is checked with everything else not selected.
Neal
Old Mar 22, 2023 | 05:17 PM
legerwn's Avatar
the laptop that your using to run the tech2win software, what OS are you using on it?
Neal
Old Mar 22, 2023 | 05:40 PM
jhall's Avatar
the laptop i got tech2win running on has windows 10 pro as well.....32bit......the laptop also says USB com port 3...it all works fine
i think the issue with the surface is they all have a usb-c port...and only 1 port and the tech2win software when it loads it also loads a usb driver...i think the driver that is with the tech2win software is not compatible with the surface drivers...i have even tried to load different drivers in the surface in the usb port with no luck....now the surface will load and run GDS with no issues....it even see's the nano in the gds software so it's down to a glitch in the tech2win software that needs some sort of tweak to make it work
Old Mar 22, 2023 | 08:20 PM
legerwn's Avatar
I found this on the subject, not sure if you seen this one;Here’s the VXDIAG VCX NANO GM GDS2/Tech2Win working experience on Surface Pro (Windows 10) tablet:
“I tried on three of my Surface Pro 2017 models (Windows 10 Pro) Everything would work except the Tech 2 software. CANDI not connected. Not matter what I tried. When launching Tech2 the popup to choose connection to the MDI wasn’t appearing. I looked everywhere for the usb drivers with no luck.
After messing around a couple days with it, I got it to work with another laptop running Windows 10 Pro.
I think the problem is that the Surface Pro runs a usb 3.0 port and the other laptop has a 2.0 port. So if you only have a 3.0 port you may run into issues. A possible workaround would be a usb port splitter that supports usb 2.0. I haven’t tried this because I didn’t have one on hand.
Are you using a usb 2.0 adapter to go from the usb c connection?
Neal
Old Mar 22, 2023 | 09:55 PM
usually you look in windows device manager to see what com port got designated to the usb device and select that from tech2win menu
