No shift 3er and 4 gear....!!!
Old 04-24-2018, 02:27 PM
Fito53jr's Avatar
Default No shift 3er and 4 gear....!!!
Reverse, neutral, 1st and second gear good, but never did the shift on 3er and up, just stay on 2nd.... never go up.... I read a post saying the after shift on second go to neutral, but not mine.... 1st and 2nd normal but stay on second.... transmission fluid is level right... no codes.... guys need help...!!!! Any idea..???
Old 04-25-2018, 02:24 PM
Welcome to HF.
Help with what?
Might be important to specify which Hummer year, model, miles, and recent work performed.
Otherwise, we got no idea what you are asking about.
So the answer is. Your transmission is broken?
Old 07-12-2018, 10:44 AM
Hungryhummer's Avatar
it's a clutch pack issue, allot of the 4l60's have that issue and it won't shift out of 2nd, into 3rd or 4th....I have a friend who has the same trans as that of the h2 in a Tahoe and it does the same thing, no 3rd or 4th but all the other gears...its a cheap fix as in parts, but you have to pull the whole drive line out to repair......best of luck
Old 07-12-2018, 11:01 AM
Unless it is an H1, which means what you suggested is irrelevant.
If people asking questions can't bother to describe what vehicle they are asking about, ain't no point in volunteering guesses. Just sayin.
Old 07-12-2018, 06:51 PM
Your right if it's a h1, then disreguard it's a Allison trans, but h2 uses a gm 4l60 series trans and transfer, and they are notorious for killing clutch packs and loosing 3rd and 4th....just would be nice if people give info about said hummer and others wouldn't be a bunch of dicks when all some of us just want to be helpful to keep these beauties rollin or those whom don't know or are looking for a direction
Old 07-13-2018, 07:22 AM
Actually if it is an H2 or H1 it could be MANY different types of transmissions.
H1
6.2L Diesel TH400/3L80 3-speed
6.5L Diesel, 5.7L Vortec gasoline, 6.5L turbo Diesel 4L80E 4-speed
2006 Alpha ONLY Allison 1000 5-speed
H2
6.0 L V8 4L60E 4-speed (2002–2004),
6.0 L V8 4l65E 4-speed (2005-2007)
6.2 L V8 6L80E 6-speed (2008–09)
No one is being a dick, just like to have accurate information on HF.
Old 08-13-2018, 07:28 PM
JB357OOOO's Avatar
Default Will running my Hummer h2 at idle with no transmission fluid damage my trany?
Old 08-13-2018, 08:26 PM
JB357OOOO's Avatar
H1
H2
Hey. Will running my Hummer h2, 2003 at idle with no transmission fluid damage my trany?
Old 08-14-2018, 08:42 AM
Hey..... what does your question have to do with no shift 3er & 4 gear involving an unidentified mystery vehicle? So much so that you had to post in this thread twice?
Glassguru
03-27-2018 09:49 AM
Zeppelin
06-20-2016 04:07 PM
hummerblu33
08-14-2015 07:01 PM
fortknox82
12-28-2013 07:33 AM
HummerH2
03-13-2008 12:04 PM
Quick Reply: No shift 3er and 4 gear....!!!
