General Hummer Talk Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
a/c off changed water pump,temp sensor,thermostat fan clutch what else is there
Old Jun 13, 2021 | 05:02 PM
danrasco's Avatar
Default a/c off changed water pump,temp sensor,thermostat fan clutch what else is there
hi i have change fan clutch ,thermostat, temp sensor,water pump im still having the p0117 code .a/c off temp gauge drops to 0 i erase code and it good for 1 min. and it comes back A/C off.
Old Jun 13, 2021 | 05:08 PM
maybe air trapped in the cooling passages.
Old Jun 13, 2021 | 05:16 PM
Wiring clusterfvck.
Old Jun 13, 2021 | 05:21 PM
danrasco's Avatar
burped system checked wiring someone said it could be gauge cluster.
Old Jun 13, 2021 | 05:33 PM
Clusterfvck--> without P0117 code. With P0117:Cause:
  • ECT sensor connector is damaged or shorted
  • ECT sensor signal circuit shorted to sensor ground
  • ECT sensor is damaged or has failed (it may be shorted)
  • PCM has failed
Old Jun 13, 2021 | 05:44 PM
danrasco's Avatar
How can i test
Old Jun 13, 2021 | 05:50 PM
danrasco's Avatar
Im new to this form dont know how it works am i missing something?
Old Jun 13, 2021 | 05:52 PM
danrasco's Avatar
Old Jun 13, 2021 | 05:57 PM
danrasco's Avatar
Well anyways thank HUMMERZ
Old Jun 14, 2021 | 10:47 AM
Welcome to HF.
Yes you are missing ................ the Year, Model, Miles of whatever vehicle you are talking about so that anybody might be able to help.
When you bother to let us know Year, Model and Miles................. I will MOVE your thread to the correct vehicle section as this new member area is NOT for Tech Questions, just like it says.
woodwardsh3
May 13, 2019 08:03 AM
RFlagg813
Apr 9, 2017 09:44 PM
Malcolm745
Dec 29, 2015 03:58 PM
joenuzz
Mar 22, 2015 08:34 AM
Waelhilal
Sep 16, 2014 08:26 AM
