H2 Doesn't warm up completly
Old Nov 24, 2015 | 04:21 PM
Malcolm745's Avatar
Default H2 Doesn't warm up completly
Ok it's getting a bit cold here in Poland about 2 degrees Celsius (about 35F) and I noticed that even during a long run my H2 doesn't heat up to more than 70 degrees (about 158 F ). I used a scan tool to connect during a trip and I checked the info directly from the computer to make sure the gauge is not messed up. I also noticed my fan working ALL the time even during a cold start. I'm not sure it should behave that way, I owned a BMW before and the fan only kicked in when the engine was at the perfect temperature. I also thought about changing the thermostat but I wanted to get an opinion from you guys.
Old Nov 24, 2015 | 10:46 PM
LoJac963's Avatar
The mechanical fan should be disengaging shortly after startup. If my garage was warm the fan clutch will be engaged but by the time I pull out of the driveway and to the end of the street the clutch has disengaged.
You fan clutch may be bad if the fan is turning 100% of the time. Although I am pretty sure when fan clutches go bad they fail in the disengaged position so the fan wouldn't turn at all.
Old Nov 25, 2015 | 12:19 AM
Malcolm745's Avatar
Thanks for the reply! Oh well guess I'll have to visit the mechanic for a closer inspection. I'll update this post after they come up with something.
Cheers!
Old Nov 27, 2015 | 08:02 AM
calif phil's Avatar
I would remove the thermostat and look to see if it is stuck open. You can test it by putting in hot water and see what temp it opens. I would probably just stick a new thermostat in if it were mine.
Old Nov 29, 2015 | 09:39 AM
Malcolm745's Avatar
I have an appointment with the mechanic on Friday will let you guys know how it goes.
Old Nov 29, 2015 | 06:15 PM
flyday58's Avatar
You are talking about the water temp, right? My tranny temp takes a looooong time to warm up since I moved to the mountains, but the coolant warms right up.
Side note: looking to switch to electric fans as soon as the holidays are over.
Old Nov 30, 2015 | 04:38 AM
Malcolm745's Avatar
Yeah it's the water temp I have problem with. However since the fan is running all the time the tranny temp barely warms up at all.
Old Dec 29, 2015 | 03:58 PM
Malcolm745's Avatar
Replaced the thermo about a week ago and all seems fine now. Case closed thanks for all the feedback.
jcap
Jul 2, 2010 05:55 AM
advsleep
Jan 6, 2010 08:24 AM
kchummer
Aug 18, 2009 02:34 PM
Muddydawg75
Apr 6, 2008 01:44 PM
SafariHummerH2
22
Jan 26, 2008 03:37 PM
