Only luke warm air on my front heater
Old Dec 15, 2009 | 03:15 PM
advsleep's Avatar
Default Only luke warm air on my front heater
Hello all,
I am new to this forum and I have a 2002 h1 with a really luke warm heater in the front heater but the rear heater is quite warm. Any suggestions on what it could be?
Any help is appreciated.
Old Dec 15, 2009 | 04:22 PM
hummech's Avatar
i would check for a plugged or stuck water valve. it is mounted on the right side of the vehicle under the hood next to and down from the coolant bottle. it is a black valve with four hoses connected to it with a vacuum line going into the top of it. when the Hummer is running, look at the plunger on the valve with the heater on the plunger should be down, with the a/c on the plunger should be up. it is a plastic valve which is held to the side fire wall with a hose clamp, if the hose clamp is too tight the plunger gets stuck inside of the housing. if that all looks good than i would remove the valve and clean it.
Old Jan 6, 2010 | 08:24 AM
hummerfamily's Avatar
mine is blowing warm then luck warm after it sounds like a switch flips under the dash. I will check the above valve and post what I find. 2007 H3 52k miles
daniel5455
May 30, 2014 05:04 PM
kchummer
Aug 18, 2009 02:34 PM
Muddydawg75
Apr 6, 2008 01:44 PM
SafariHummerH2
22
Jan 26, 2008 03:37 PM
Doc Olds
Sep 1, 2007 02:35 AM
