my Hummer h3
Old 09-17-2015, 09:17 PM
greg903's Avatar
Default my Hummer h3
Just got my 2007 h3 3.7 and so far all is good should I get ready for any problems
Old 09-18-2015, 09:00 AM
Bunger's Avatar
If you don't know the service history, the first thing I would do is change ALL of the fluids, clean the throttle body and MAF sensor.
Old 09-18-2015, 09:33 AM
greg903's Avatar
Default my h3
Thanks for the information will get that done
Old 09-25-2015, 03:20 PM
norinco3264's Avatar
Default Things to check
I'd take a look around the forums, a few searches should pull up a few threads regarding common problems.
Along with changing out fluids, I would;
-Check radiator.. it commonly develops a hairline fracture across the top.
-Check CV seals up front. Seems like the tend to leak.
-Inspect your moonroof if you have one. The drain plugs often clog, potentially causing wicked electrical issues.
-Inspect/replace battery terminals. Stock terminals are absolute junk and will eventually cause problems down the road.
-Make sure your AC operates properly. They just issued a recall regarding the blower motor resistor harness. Look into the recall.
Just a quick list of things I could think of. Enjoy!
Old 09-25-2015, 06:22 PM
happythree's Avatar
spend some time reading many posts here and learn a lot.
Old 09-25-2015, 07:54 PM
Happy Hummer's Avatar
For the 1st year I just tried to drive and smile. Pretty much made it.
Old 09-26-2015, 08:25 AM
greg903's Avatar
So far it's great to drive. It has a miss but I hope it just needs a tune up. Otherwise in good shape.
Thanks for all the information. Well definitely enjoy it
