my Hummer h3
I'd take a look around the forums, a few searches should pull up a few threads regarding common problems.
Along with changing out fluids, I would;
-Check radiator.. it commonly develops a hairline fracture across the top.
-Check CV seals up front. Seems like the tend to leak.
-Inspect your moonroof if you have one. The drain plugs often clog, potentially causing wicked electrical issues.
-Inspect/replace battery terminals. Stock terminals are absolute junk and will eventually cause problems down the road.
-Make sure your AC operates properly. They just issued a recall regarding the blower motor resistor harness. Look into the recall.
Just a quick list of things I could think of. Enjoy!
