my Hummer h3
Just got my 2007 h3 3.7 and so far all is good should I get ready for any problems
If you don't know the service history, the first thing I would do is change ALL of the fluids, clean the throttle body and MAF sensor.
my h3
Thanks for the information will get that done
Things to check
Originally Posted by greg903
(Post 329947)
Along with changing out fluids, I would; -Check radiator.. it commonly develops a hairline fracture across the top. -Check CV seals up front. Seems like the tend to leak. -Inspect your moonroof if you have one. The drain plugs often clog, potentially causing wicked electrical issues. -Inspect/replace battery terminals. Stock terminals are absolute junk and will eventually cause problems down the road. -Make sure your AC operates properly. They just issued a recall regarding the blower motor resistor harness. Look into the recall. Just a quick list of things I could think of. Enjoy! |
spend some time reading many posts here and learn a lot.
For the 1st year I just tried to drive and smile. Pretty much made it.
So far it's great to drive. It has a miss but I hope it just needs a tune up. Otherwise in good shape.
Thanks for all the information. Well definitely enjoy it |
