How to upgrade the rear camera
In an ideal situation the rear camera would be above the license plate like the Escalade. But since we have a swing out carrier it's above the hitch and the visibility is useless. Not to mention it has no distance lines to help judge how close you are to things that you can see.
So has anyone come up with a better solution? I'd still like to see my hitch so I can use it to back up to the trailer as well. Is it possible to wire up a newer wider angle camera to the stock wiring?
Mine is aftermarket, but it's on the top of the license plate on the swing out carrier and it has distance lines. I don't remember the model, but I'm sure there are plenty of similar options out there. Obviously I can't see the hitch.
Were you able to tie your aftermarket into the factory wiring or did you have to run all your own wiring?
Just to be clear, I paid a shop to install everything. I can only tell you what, and take pics if you want, but I can't tell you how.
Just fitted an aftermarket Pioneer system with the backup camera mounted on the swing-out carrier just below the number-plate rather than above to avoid issues with the light and heat from the number-plate bulb.
The system generates the guidelines rather than the camera, there didn't seem to be any aftermarket cameras with self-generated guidelines available. The guidelines needed to be calibrated for distance and side zones limits using markers on the ground and since the view is from the rearmost extremity of the SUV it does provide great confidence when backing-up.
The position is not so good when hitched but still provides useful feedback about the trailers position.
Great camera
Aggiedad04
06-07-2018 03:28 PM
TexasNative83
12-17-2011 05:56 PM
samkelly
01-17-2009 07:59 PM
jstdoitt21
10-27-2006 11:19 AM
